antifreeze
Bruce
Bruce Member Posts: 27
I just bought an 11 litre bucket of propylene glycol and it said please add corrosion inhibitors.Can anyone tell me what I should be adding, or should I be checking the ph first .It is a new system. Thanks Bruce
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Check the pH first,
    it will save you a lot of money and grief, FACT!
    hot_rod Member Posts: 26,607
    Did you get food grade!
    What does the label indicate it is for? Typically all hydronic glycols come with an inhibitor package installed :)
    Although you can add the package or booster. Maybe it is available from the same supplier that sold you the glycol.
    Local Chem shops could blend the inhibitor for you. Try Scott at www.rhomarwater.com for product, also.
    Either buy an inhibitor, and blend it in, or return the stuff you bought and get an "inhibited propylene glycol" suitable for hydronic systems.
    Dow, Noble, Hercules, Utility, are a few of the common names in the industry.
    hot rod
  • Drew_2
    Drew_2 Member Posts: 158
    Antifreeze
    We have a non-toxic food grade inhibitor. It's the same as we blend into our Noble/Noburst-100 product. Will you need a defoamer? Drop me an Email or call me and we can go over the details. 1-800-678-6625, Ext. 108
    Drew
