Quik-trak on slab question
Greg Durgin_2
Member Posts: 7
I am hoping that The Wall can share some expertise/experience on a mud-room radiant panel floor job we are working on this week.
Rubber tubing installed in the 1980's has failed in a grade-level 4" concrete slab (with 2"rigid insulation below). We will remove the existing thin-set ceramic tiles and install Wirsbo quik-trak on the slab. The radiant "sub-floor" will be covered with backer-board and the finish treatment will be large ceramic tile laid in thin-set. The heat loss calcs work out fine.
How would you suggest we attach the quiktrak panels to the slab? Would a strong adhesive (like PL400) be sufficient? Powershots?
And how would you affix the tile-backer board (3/8") to the quiktrak (1/2")? Adhesive? Usually, with a wood sub-floor below the quiktrak we would just screw through.
Thanks for your thoughts.
Greg
Greg
I think I heard about a cool tool here on the wall
http://www.itw-ramset.com/trakfast_index.asp
looks like a good excuse for another tool:-)0 -
Trakfast
is the tool I have used.It works well in this situation and is cheaper per shot than a Hilti type.
Since the floor already has radiant I assume the slab is insulated below.I would attach the climate panel/quicktrack directly to the cement.The tile backer is than installed with thinset and more of the same Trakfast pins.
I did my showroom in much the same way and it worked out very well.
Trakfast
Thanks Paul and John.
That looks like a nice tool.
I have a hilti so can use some pins for both layers.
Yes John, there is insulation below the slab.
Thanks again for the advice.
Greg0 -
Float babyyyy
We've done it with a thin pad underneath then floated the climate panels and covered with 3/8 plwood stapled to the panels to lock them together topped that with floating laminate wood and carpet worked great. probably not stiff enough for tile though.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
