Question on Infloor Heat Inc. Manifold Assembly?
Brett O'Connor
Member Posts: 22
Went out to a jobsight that we have done the design on the existing system and the addition. The existing system has 2 Infloor Heat Inc. Manifold that have a pump mounted on them with what looks to be a mixing devise with a 24 v power relay, boiler end switch, and thermostat connection. My question on this is that I need to insure that this is truly a mixing devise. I am re-doing the mechanical room with a 311 Pro Panel were as the mixing side will be handling the new construction and I can use the boiler demand to send 180 degree water out to these existing manifold. Anyone that has information on this would be greatly appreciated.
Thanks,
Brett
Thanks,
Brett
Infloor Manifolds
http://www.infloor.com/
is their site. I wish you well.
I never liked these manifolds. Nice idea, but poorly executed. Hate that cheap rod/spring assembly.
Just my 0.02 worth.
Good Luck
Terry
- 125 Chimneys & Flues
- 120 Geothermal
