Wax or no wax
J Matthers
J Matthers Member Posts: 24
With warmboard low temp radiant should I use a wax ring for the WC or a rubber one? Don't want any suprises with melted wax!
  • Al Letellier
    Al Letellier Member Posts: 781
    wax options
    We've always gone by the rule that if you stay 12" away from the toilet you can use a wax ring, but I generally use the rubber one to be safe, especially on upper floors with large sheetrock ceilings.....architects just love to put a toilet right over the dining room ceiling!!!
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Honestly
    I have NEVER EVER heard of a wax ring melting due to radiant floor temps!
    John Barba of Wirsbo called a wax ring manufacturer and asked what the melting point of the wax was. It was MUCH higher than you would EVER run a floor temp at.
    In my area there are Levitt style homes with copper tube buried in the slab. I have seen DOZENS where the heating contractor ran the temps on the boiler to 180* with NO attempt at tempering the supply water. Those slabs cook in the winter, until the homeowner calls me and I fix it, and the wax rings DO NOT melt.
    Mark H
    hot_rod Member Posts: 26,595
    Error on the safe side
    Grab some of the rubber types, available at plumbing supply outlets. I have never had a meltdown either, but then again never say never! It only takes one to ruin your day.
    hot rod
  • David_5
    David_5 Member Posts: 250
    Wax ring
    If it doesn't melt in a 120 degree truck why would it melt on the floor?
  • ross
    ross Member Posts: 37
    on the other hand...
    heat doesn't do great things for rubber products, either. I don't have direct experience in the matter, I might lean towards the old wax ring. Maybe you can do an experiment. If you have an old pot, you could try boiling a pot of water and put the wax ring in it and see if it melts. If you have a thermometer, you could monitor its progress and see at what temperature it melts (if it does).
  • They sure as heck melt if you
    put 160° F boiler water into the toilet.
    Ask me how I know....
  • Steve Bergstrom
    Steve Bergstrom Member Posts: 19
    better safe than---
    sorry so I called PREDCO @ 1 800 3236188 and had them send me some of thier Ultra Seal Water Closet Drain Connectors.They worked real slick.They can be reajusted up incase you want to put tile under your WC later.
    Good Luck Steve
  • Floyd_3
    Floyd_3 Member Posts: 32
    That's funny....
    the guy's at Watts claim that their rubber tubing will last FOREVER!!!!!
    I guess that means you aren't a fan of rubber tubing either.......
    That's okay neither am I :-)
