heat pump
aubrey
aubrey Member Posts: 1
I have open loop heat pump with secondary heat exchanger that produces hot water, which is circulated by a small 110 volt circulating pump, only in heating season (Dec. _ Mar,) During this period, the electric supply to the hot water tank is shut off. How can I contol the water temperature at the tank, so that the secondary heat exchanger will not run, yet allow the primary to heat my house?
  • Tony_8
    Tony_8 Member Posts: 608
    step one
    Find your installation manual. If not available, call manufacturer w/ model & serial numbers so they can send you another.
