Back-up files
Mark Hunt
Member Posts: 4,908
THEY ARE A GOOD IDEA!
I just lost EVERYTHING I had on the computer.
I think Murph did it!
Back em' up boys! I learned my lesson.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Mark H
Back up Software
When you look at backup software, make sure it does exactly what you need for it to do.
Some backup software just saves some of your data files. We use GHOST and actually make a duplicates (Clones)of our critical drives. Windows can't tell the difference between the primary and the backup. This means you don't have to go through the hassle of reloading, reconfiguring and reregistering software. You remove the bad hdd, physically replace it with your clone and your back in business.
Every Friday we run a clone of all the drives. This takes about an hour for four 80mB hard drives.
Also, once a month we run a clone set and store them offsite in case of a fire. This may sound like alot of money for HDD, but think about how many hours it would take to get your system back to where it is right this second. You'd be surprised how cheap hard drives have become.
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com0 -
Yup,
I bet it WAS Murph'!!!!!!
Too bad we can't see the IP addreses anymore.... maybe that mad Russian is Murph' also......
just causin' trouble as usual......0 -
i seen your
handiwork yesterday....... I think you really get a howl from bringin down the wall. good thing dan was resourceful and got a back-up copy!!
Murph'0 -
One touch backup
Maxtor makes a one touch backup system in various capacities. Very simple and effective. Essentially it is an external hard drive bundled with software. Also, CD burners are dirt cheap these days but are more time consuming.
http://www.maxtor.com/en/products/external/personal_storage_5000/index.htm0
- 125 Chimneys & Flues
- 169 Indoor-Air Quality
