What is the best way to
balance a radiant loop! Monitor temp.on each loop or in a postI saw from Hot Rod a flo meter???How do you know if your heat in that loop is too much or not enough???I know a dumb question but have to ask!! Thankyou Richard
  • Al Letellier
    Al Letellier Member Posts: 781
    balancing radiant
    It depends what you have for manifolds as to how to balance, if you have multiple loops in a room, but I found that once you "set to specs", run the system and use a thermal gun to check floor temp. If you installed the system or not, floor temp will always get it balanced and is the ultimate test for comfort and even distribution of heat.
    We always have the customer do "the barefoot test" once the system comes on steady...they will tell you where the hot or cool spots are!
