Swedge fittings
Hot Rod for the info...Richard
  • Richard D._2
    Richard D._2 Member Posts: 156
    Hey Hot Rod
    Missed your post about your swedge joints!!Was it quicker??Any cracking of the tubing??Does M pipe swedge with any problems??Is it faster when you get used to it?? Thanks Richard
    hot_rod Member Posts: 26,604
    Swedge options
    To use the hand one you need to heat and soften the tube.
    This nifty REMS electric one will swedge with just a squeeze of the trigger without softening, although the tube gets smokin hot while it expands:) (wish it were cordless) It also doubles as a tee puller.
    hot rod
  • Bob_19
    Bob_19 Member Posts: 94
    Is This
    the same as swaging soft copper?
    I'm just curious, is it called swedging because the tube does not have to be softend?
