Microsoft Patch Download is here if you need it.
Tom Meyer
Member Posts: 300
If you want to check if you need the MS Worm patch, here's the steps to check:
1. From the Start Menu, select Settings, then Control Panel.
2. In Control Panel, Select Install/Remove Programs.
3. Within the list of installed programs, scroll to "W" in the alphabetical list of programs.
4. If you have received the patch, you will see a listing for "Windows 2000/XP Hotfix - KB823980". The number is important. If you see a Windows Hotfix entry but do not see this number, you need to apply the patch.
If you need the patch, I have two versions as attachments. One is the direct .exe file and the other is a zip file. After you download the patch to a file in your computer, click on the download icon and follow the instructions.
Or you can go directly to the Microsoft download site.
http://support.microsoft.com/?kbid=823980
I've heard it's pretty busy lately.
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
