Boxi-Luna ??????
Ted_5
Member Posts: 272
Has anyone installed one of these? The construction of the heat x looks ??? What is this company back ground? Any info would be helpful. Thanks in advance.
Ted
Ted
That would be
Baxi Luna. Baxi is huge in Europe. Very good stuff.Retired and loving it.0 -
Baxi-Luna
We've installed two so far; both are combi units (heating/DHW) and they work extremely well; just remember they only provide about 3½ GPM of 130° water. Just enough for one fixture at a time.
Baxi Luna \"Ocean\"
We've installed a few, one thing to be careful of is short cycling. (low mass equipment) 2 of the ones we put in we used a buffer tank, this helped alot.0 -
How much does that add to the cost
of the installed price? Is there out door reset in this
boiler? What is the efficiency? I would like to know what the advantage is over other wall hungs.
Ted0 -
baxi
Have installed quite a few of this units with good success,
the DHW production is about 2 GPM @ 100° temp rise and about
2.3 GPM @ 90° temp rise, to which they will perform. There
is also a time delay to firing in DHW mode of about 10 - 12
seconds, just be sure to inform system operation to end user. Gas pressure settings are very important.
Also btu output settings on a heat demand should be set to
as close to the heat loss as possible, this will help in short cycling. My option, heating only boiler with indirect
(good quality) and a DHW priority control.
Heating only unit can also be setup with 2 firing rates.
baxi
(good quality) and a DHW priority control is the way to go.
This investment is also not that much more, the heating only unit can also be setup with 2 firing rates.
ps - and less parts!
baxi
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
