TRV's
Dave Palmer_3
Member Posts: 388
anyway to tell which side is supply or return on hot water radiators? Can't see pipes in the basement,going to the second floor,plastered ceiling in basement.Customer wants to zone the second floor so I thought TRV's would be idea for this,any ideas? Hate to put it backwards,Thanks Dave Palmer
Turn on the system
and see which side gets hot first.
Hope that helps!
Mark H
that
would be great but the boiler is gone. They pulled it,then told me they wanted it zoned,ugh. thanks Dave0 -
Hmmmmmmm
How about a smoke test?
Or disconnect the rads and try pressurizing the supply main with air?
Mark H
Dave, are those rads
connected with one pipe going in the top and the other in the bottom? If so, the top is the supply- or if it's not, the rad won't heat properly. Ask me how I know that.
If theyre connected with both pipes coming in the bottom, the end opposite the air bleeder is most likely the supply.
If you're not sure, pressurize the supply main as Mark said. You don't need much- a blow-dryer will do. Shut off the valves to the first-floor rads when doing this.
I wouldn't put a TRV in the bathroom. This room needs to run at full temperature to reduce the moisture that lingers after a shower. If the room is too cool, mold can accumulate.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
bleeder and supply
mine are bottom-bottom and the bleeder is on the supply side. Isn't the only thing done nonstandard - part of the charm of an older home :-)
Mark0 -
TRV
If you can use a rad vlve with double unions it will easy to change direction in case you guessed wrong.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
