Bi-metal snap disc thermoswitch
Hello. I am looking for a bimetal surface mounting snap disc thermoswitch for the cooling system on my RC car. I would like to mount it to the surface of the cooling head with either a mount or some heatsink glue. An ideal size would be about 1/2" sq or in diameter. If you might know where I can find something like this it'd be appreciated. Thanks.
  • Eric Taylor_35
    Eric Taylor_35 Member Posts: 29
    Here's some
    http://www.ti.com/mc/docs/precprod/docs/
    You got a water cooled RC car?!?
    Sweet.
    I thought they only did that with boats.
    I've got a Pirate 1/10 scale with an O.S. .21 motor. Goes through tires like mad. (and gears, tie rods, clutch shoes, bodies, and axels too.)
    32,000 RPM on a two-stroke diesel running 20% nitro.
    Big fun!
    Eric
  • tim smith1
    tim smith1 Member Posts: 26
    thermodisc
    check with local heating parts supply house. White rodgers makes many different temps of limit switches that could be affixed to that.
    hot_rod Member Posts: 26,607
    Check with
    Graingers and Johnstone theyhave online catalogs. Kickspace heaters come with some small diameter ones.
    What are you trying to control. I wonder that the RPM vibration "buzz" will rattle the brains out of those snap discs. Any way to use a thermistor type of sensor? Have fun!
    hot rod
  • Eric Goodrich
    Eric Goodrich Member Posts: 5
    Thank you.
  • Hi Eric
    Be careful of our grandson with that car (GRIN)
    I wrote you about one that I can buy.
    Noel and Lisa
