Screen shots from Hydronic Design Toolkit
ScottMP
Member Posts: 5,884
I gotta have it !!!
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Scott
here is
on of the modules from Siggys new software. It allows you to basically build a system. Select the pump from a menu of B&G, Armstronng, Grundfos, Taco.
Select the PAB (pressure activated bypass valve) brand and size switch it on or off. Turn zones on or off with the toggle.
Build your heat emitters from a menu of various brands and sizes of baseboard, radiant slabs, gypcrete, or plates above or below.
Add balance valves and adjust them! All inputs show the change in flow and pressure drop. Pretty cool and very user friendly.
hot rod
HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
try this pic
A handy
expansion tank sizer with a system volume calc. Very handy!
hot rod
How about this
Basement calculator. It allows bermed and daylighted input. It moves to thr main heat loss calc window. Nice touch.
For an eye opener!
plug some figures into the pipe loss calculator. Chose different air temperatures and insulation thickness and type.
I modeled some 1-1/4" near boiler piping, in this example. Maybe I should have uped the flow rate
I downloaded the demo
a few days ago. I must have played around with it for 3 or 4 hours. Plugging in different baseboards, different pipe sizes and seeing the temperature drops. Really amazing. I am waiting for my "full copy" now. Took all of about 30 seconds to make that decision. Seems like a really amazing tool. And the neat part is there may be more added. I cant wait to see what is next. Now all I need to do is find a screen saver that "trims out" a boiler as it sits, maybe start with an old steam, then to gravity hot water, and move on up through the years to a nice condensing boielr with a raidiant system, with an indirect
Chuck Shaw
Wishing him
all the success in the world. He deserves it.
Thanks for all that you do for us, Siggy.Retired and loving it.0 -
You sold me
Can you post the link to the site?
Thanks.
J0 -
i believe it is
www.hydronicpros.com
Chuck
Just got my copy
today, started to play with the full version. This thing is neat. It has already answerd questions that i never had answers to before.
Chuck Shaw
You guys
are great salesmen. I just ordered mine. Can't wait. WW
I feel stupid,the order page listed
test product @ 1.00 each so i bought two. I get a refund check for $0,000,002.00 in the mail today !■■:═µ
it was just from the computer people well ...testing0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
