5/16 couplings x23
paul lessard_2
paul lessard_2 Member Posts: 192
when you are on a job keep pressure in pipes at all times,
some people just enjoy messing with other people's stuff.
got razor knife??
  • Al Letellier
    Al Letellier Member Posts: 781
    5/16 couplings
    Nice work Paul. Finally nice to see someone who cares about the way his soldered joints look.....A lot of buffing or are you really that good at it???
  • Floyd_3
    Floyd_3 Member Posts: 32
    Nah.....
    He gets Nadine to buff those joints... It keeps her busy and outta his hair!!!!
    But...... MAYBE she...... did that soldering... bet a woman could make a neater joint anyday!!!!!
  • I count 17
    We estimated that there was nearly 2 miles of 5/16" hePEXplus in that place but that's a lot of damnage.
    Where did you find the leaky tubing?
    I'm guessing that most of those were damaged inside of the Q.Track from the Misc. small trade debris from above. Nails,sharps ETC.
    Is someone going to get wacked on that job?
    G.man
  • paul lessard_2
    listen all ya all it's sabotage
    all holes were made from a razor knife,This tubing was installed early on,it's a good thing I held off on the rest of it...yea 23 couplings no ****.
    and those joints are rubbed with a rag only thanks ...
    paul maching gun lessard.... ..... ..... ..... .....
  • paul lessard_2
    all holes were made from a razor knife,This tubing was installed early on,it's a good thing I held off on the rest of it...yea 23 couplings no shi?.
    paul machine gun lessard.... ..... ..... ..... .....
  • paul lessard_2
    sabotage
    they were all razor knife holes,all 23 of them.
    another wasted day on the job that will not end. thanks those joints were just rubbed with a rag. paul machine gun lessard.... .... .... .... ....
    hot_rod Member Posts: 26,594
    Water test that baby!
    I had a similar thing happen to a Warmboard job. Turns out the hardwood installer was cutting his red rosin paper on top of the floor with a razor knife!
    Real hard to find knife slits with just an air test.
    I ended up replacing several loops to be sure I didn't miss any spots. Not all the cuts went entirely through the tube. That would haunt me forever.
    hot rod
