New literature available from B&G - Dan H
DanHolohan
Member, Moderator, Administrator Posts: 16,686
Morton Grove, IL.June 6, 2003 - A new bulletin (A-109B) that provides operating data and other useful information on Bell & Gossett's line of bronze and stainless steel Wet Rotor Circulators and accessories for potable water systems is now available.
In addition to helpful operating data, the one-page, color bulletin provides information on performance curves, materials of construction and a chart with all available model specifications. The bulletin also highlights accessories, including an automatic timer kit and aquastat switches.
The circulators can be used in potable hot water applications and come in flanged, union, and sweat connection models, as well as low-watt, energy-conserving models. All the circulators are 100% lead-free and offer the B & G Dura-Glide® Bearing System, assuring whisper quiet and maintenance-free operation.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
