Sizing pipe for reverse return system
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
when you talk like that.
John Siegenthaler has written software called Hydronic Design Toolkit that should provide you with what you need. It's available through the RPA website:
http://www.radiantpanelassociation.org/i4a/store/category.cfm?category_id=2
You can also email John to make sure it's included in the software:
JohnSiegen@aol.com
Best wishes,
Alan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
JohnSiegen@aol.com
Best wishes,
Alan
Reverse return hot water pipe design
The calculation of flows in a reverse return seems to require a simultaneous solution of non-linear equations.
( head = constant * flow to the 1.75 power ).
Is there software that will calculate the flow in each segment of the system, given the pump head and the geometry of the network?
- 125 Chimneys & Flues
