Best circulator pumps
LD
Member Posts: 26
Someone one recommended to me the 'best' brand of circulator pumps to use in my HW radiant floor setup.
He either said Grundfos or Danfoss. I can't remember.
Any opinions on which brand I should specify for my contractor to use or is it not significant?
trust your contractor
not your circulator. When you buy a car you don't ask what spark plugs the car has. The important thing to buy is the contractor and the system.
P.S. Danfoss does not make circulators (to the best of my knowledge).
Michael Bleier
Able Distributors
"The Supplier Who Works With You"
www.abledistributors.com0 -
Grundfos
Three year warranty, most have just one year. Optional three speed pump for about the same price as a one speed pump gives you lots of options on where you can use it, and an optional built in flow check, have used Taco and Grundfos since 1977, Taco is ok, Grundfos is better.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
