I got great Munchkin service
ScottMP
ScottMP Member Posts: 5,882
Jeff from Heat Transfer Products, aka the Munchkin Guys, sent Rick Sousa up to a problem job and customer,to help me out. The customer was getting cranky and needed a little hand holding. Jeff said no problem to coming out. He was'nt able to make it, so I got Rick Sousa, tech extrordiniar.
I feel alittle stupid since the problem was the differential and it was diagnosed in about three minutes of listening to the customer. We had it set to high, which resulted in too low a temp being circulated.
The heat would overshoot and then drop about five degrees. I was stuck on the heat aticipators. Rick came in, listened to the customer and went right to it.
He also did a nice job of complimenting our install in front of the customer.
Big Thanks to Rick and Jeff.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Wayco Wayne
    Wayco Wayne Member Posts: 615
    That's good to hear.
    You never know until you need help. It's a bonus it was something relatively easy. I've had trouble wrapping my mind around how the modulation works with the differential. No one has described it to me in a way that I understand. I'll keep trying. WW
  • chuck shaw
    chuck shaw Member Posts: 584
    I'm not suprised
    whenever I have had a Munchkin question, Jeff Cook, John Sawyer or in one case Rick, have been right there for me. There is a bit of a learning curve to any new product. And as the curve has flattend out an I have become more comfortable with it. The HTP people have been there all the way for me.
    Chuck
  • Troy_3
    Troy_3 Member Posts: 479
    I'll second that
    I have had wonderful support from everyone at HTP. The owner is right there if everyone else is busy. That is amazing in my mind. My rep is very helpful also. If my rep can help I would rather not bother the factory. They are working at a breakneck speed. It's nice to see a US company having such success.Any product will create questions. I've been waiting 6 days for a reply from another company. That is unacceptable. Manufacturers should notice- we do care about support.
  • paul lessard_3
    paul lessard_3 Member Posts: 186
    same here nm .....
    > support.
  • paul lessard_3
    same here nm .....
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    HTP
    If you could buy stock in this company you would be a smart investor doing so.
    The cream rises to the top.
    They will have their place along side the other great companies that advance our industry.
    Mark H
