Heating a bathroom but lack of space for BB???
anthony_7
Member Posts: 72
I dormered upstairs and put in a bathroom 7 X14. I have lack of floor space with fixtures going in TUB, SHOWER TOILER VANITIES ETC. What is an inexpensive alternative to use instead of BB on the floor as I have no room. I priced the kick space heaters and they are pretty pricey.
How about something else?
Wall-Hanging Steel Panel Radiator?
by Runtal (or others)?
If tying into an existing one-pipe system pay particular attention to your incoming/outgoing temperatures lest you overheat/underheat the space or (worse) starve whatever follows in the loop. (Have heard that kickspace heaters are particularly difficult, or nearly impossible, to add into an existing loop.)0 -
Bathroom heat
Anthony, Baseboard is the least expensive alternative to heating your bathroom. If a toe-kick heater is too pricey then you have pretty much ran out of options already. You could put a electric heater in, but you will find that the cost of operation makes that toe-kick look pretty cheap. Also the toe-kick would be easily incorporated into the existing system. Hope this helps.
What about radiant anthony?
Can't beat it for comfort and space-saving Mad Dog
How much space...
do you have? if you only have 2 feet try some high output baseboard. ex. Sterling Senior. 750btu /ft vs stndard baseboard at 600btu. If all else fail get it in the back area of the toilet...not my 1st or second choice. but sounds like the budget is very tight...kpc0 -
Baseboard
With some baseboard you can install two tiers of fin tube...did that in my bathroom with about 2-1/2 ft. of baseboard space, & works fine.0 -
Baseboard
lack of space for baseboard
cast iron tub ? we have installed bare element behind the tub, which heats the tub, which heats the room. just a suggestion. bob0 -
but a good...
suggestion nevertheless.....kps0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
