Radiant panel
antman
Member Posts: 182
I need to install a 5' piece of radiant panel baseboard, that a customer purchased for a bathroom.
I was wondering how to insatll this on an existing 3/4" baseboard loop. I was think about connecting the loop in the floor and hooking up the panel with a regular and venturi 3/4"x1/2" tee, since the panel has 2 pieces of 1/2"o.d. tubing 1-high 1-low, and the end covers wont accept anything more than 1/2" was going to use a tee to tie in each end of radiant panel and install a coin vent on one end.
Am I on the right trak or does soemone have another suggestion.
Thanks, Ant
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=239&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks, Ant
sounds
about right to me...just keep the run to the panel as short as possible... is there a TRV on it? Wouldn't want that blocking the flow...kpc0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
