Pressure test Manifold?
anthony_7
Member Posts: 72
I am pressure testing my manifold for radiant tubing prior to it being installed. I am having issues though. No matter what I do the pressure gauge I am using is leaking. I am using a 1/4" gauge off my compressor to test. I have the following
3/4 ball valve then a 3/4 tee with the gauge on top with a reducer and then I have my 4 port manifold with ball valves on each supply line closed. Every time I fill with air there is pinhole leaks coming from the gauge connection to the 3/4 male threading.
I tried another HD gauge but all I can find is for water. Is there something cheap I can use to test this I just need it for the 24 hour pressure test when the mud is laid.
Do I really need to teflon wrap these fittings as its air coming through? Am I putting to much pressure in the manifold with no tubing installed and it can't handle it?>
HELP..
HELP..
Tape and dope it !
John@Reliable0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
