wax-free bowl gasket
Baker_2
Member Posts: 1
About two weeks ago someone here mentioned wax-free toilet gaskets.
I've tried to find feed-back online or at the hardware store. One consumer
opinion I read said it worked with a newer low volume tank, but not the older
higher volume tank . I would be using it on a cast iron flange.
I wonder how long the rubber o-rings last and how well they conform
to the inside of an old pipe. But of course I am most interested in their
ability to prevent leaks. And I am curious about anyone who may have
been using one on a pretty active toilet for a while now. Have they been
around long enough to get an idea of failure rate?
Have a look at
www.fluidmaster.com0 -
Gasket
Do you need it for a radiant application? If not, whats wrong with wax? Or another option you have is to use a felt gasket. Chris0 -
Gasket
Trouble with wax sticking
i use the fluid master gizmo when i do a service call with water leaking out of the bottom of the bowl.some times the wax did not sick to the bottom of the bowl or the closet flange is down below the floor. an old trick my father taught me was to take a torch and heat up the bottom of the bowl so the wax "takes" to the bowl.
ggood luck Don0 -
This gasket
is a 3/4" thick foam rubber type product (not unlike the tank to bowl gasket) also comes in 1". I'd be glad to mail you one if you need. About 3 bucks at plumbing suppliers.
I think Harveys also has some wax coated foam jobs, if you are really on a wax kick
I also used some Predco (sp) brand that used to be advertised in PM mag. Designed by a plumber for radiant applications. Haven't seen them in awhile, however.
I'm not real inpressed with the Fluidmaster wax less approch. Too many parts and doesn't look like it would seal on cast or near a sharp bend.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
This gasket
is a 3/4" thick foam rubber type product (not unlike the tank to bowl gasket) also comes in 1". About 3 bucks at plumbing suppliers. I think Harveys also has some wax coated foam if you are really on a wax kick :)a
I'm not real impressed with the Fluidmaster wax less approch. Too many parts and doesn't look like it would seal on cast or near a sharp bend.
seal
My new way is wax , then I take plumbers putty & put it on top works well0
- 125 Chimneys & Flues
