Clearance from exhaust to windows
Kent D._2
Member Posts: 1
I am installing a direct-vent propane boiler, in the basement, that utilzes an intake/exhaust manifold. The manifold will be located between the first floor joists just above the top of foundation wall. What minimum distance is required, per ICBO, to the nearest window (on the first floor)? Also, what minimum distance is required from the manifold to the fresh air intake for a fireplace?
Thank you for the help.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
