GALVANIC REACTION - HEAT TRANSFER PLATES
Kent D.
Member Posts: 9
Will using standard steel wood screws to fasten aluminum heat transfer plates to subflooring create a galvanic reaction? My impression is that, in the absence of water, no reaction will occur. The joist bays should be dry and therefore no reaction, right?
Otherwise, what type of screw should be used? - Stainless steel? - Pricey!
Here in Humidity Heaven.......
if there would be any issues, they would certainly show here. I have some 5 year old extruded plate systems with no evidence of corrosion and I've used screws, nails and staples. You're correct, unless there is water present, it's a non-issue.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Same thing
Abt 4 years old, plain steel screws. Extreme humidity area. No corrosion from aluminum/steel or copper/aluminum.0
- 125 Chimneys & Flues
- 120 Geothermal
