balance/control valves
james g grady
james g grady Member Posts: 3
i have new steam boilerinstalled .one raditor on first floorkept blowing steam through valve.what is best way balance steam system. thank for your imput.
  • joe_15
    joe_15 Member Posts: 3
    blance/control valves
    does it matter where you put these i have seen them desinged both on the supply and return. Also seen the blance on the return and control valve on the supply. is there a reason or just the engineers prefence ?????
  • Tom Anderson
    Tom Anderson Member Posts: 40
    It does not matter. The pressure drop across a hydronic balance valve or a control valve is the same, regardless of whether it is installed upstream or downstream of the terminal device.
    Traditionally, most designs show balance and or control valve at the outlet side of terminal equipment. From what I have gleaned after 20 years of wondering why this is traditionally done, it is because the control/balance valve sees cooler fluid temperatures in a heating application... which allows the device to withstand higher system static pressures (important in a few special applications). In a chilled water application, the valves experience warmer fluid temperatures, thus less "sweating".
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    balance on return
    my understanding is that having balancing valves on the return keeps the pressure up in the circuit and this in turn helps keep air in solution.
    Mark
  • james g grady
    > imput.
  • Bryan_5
    Bryan_5 Member Posts: 270
    James,
    In order to get the most help post your question in a new thread.
    Bryan
  • james g grady
  • flange
    flange Member Posts: 153
    install new traps
