From B&G
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,724
Stainless Steel Wet Rotor Family of Circulators - SSF-12F/LW
Morton Grove, IL.May 5, 2003 - Bell & Gossett has introduced its newest addition to its wet rotor family of circulators. The SSF-12F/LW is a flange connection, stainless steel wet rotor circulator that features a low watt motor for reduced energy consumption.
Available with a powerful 115/1/60 motor, the energy efficient
SSF-12F/LW consumes only 55 watts of power, resulting in low electricity cost. The durable, stainless steel pump body casting of these circulators makes them ideal for domestic hot water recirculation systems in residential and light commercial plumbing applications.
With a maximum working pressure of 150 psi and operating temperature of 230F, the new SSF-12F/LW exceed most current code requirements.
The DuraGlide® bearing system in the SSF-12F/LW incorporates several components that work together to maintain consistent start-ups and trouble-free service. Double-Sintered carbon bearings, a ceramic shaft and generous clearances allow the circulator to resist calcium and chloride buildup.
Additional features of the new circulator include:
When installed in a recirculation system, the SSF provides the luxury of instant hot water at the tap while preserving our natural resources.
High quality, stainless steel pump body is more rugged than stamped and welded bodies.
DuraGlide bearing system assures whisper quiet operation.
Powerful motor provides dependable start-ups, extending the operating life.
Flange connection with 3/4", 1", 1-1/4", and 1-1/2" sizes.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone +1.847.966 3700; fax +1.847.966 9052; or visit www.bellgossett.com.
Retired and loving it.
