munchkin boiler
Mark Hunt
Member Posts: 4,908
that you get some background on the Munchkin before you jump into an installation.
I have quite a few Munchkins out there and quite a few more waiting to be installed. It is a great boiler and HTP is a great company. Talk to your local rep to see if there are any classes planned in your area.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Mark H
My customer wants high efficency. I'd like to install a munchkin boiler.Is there anything I should watch out for when istalling this boiler on a system with cast iron baseboard? Also, I'd like to download the installation manual if possible. Any suggestions where I could find it?0 -
their web address is...
www.htproducts.com...you wiil need to do some reading for sure. I woud put a Y strainer in on the return and clean the system w/ TSP before you let the water plug up the waterways...ie. before the old one comes out. There are other choices for high eff. A good quality Buderus g124 run on outdoor reset comes to mind...but the munch is a good choice...kpc0 -
The addvice below is correct thanks guy's
Stan call me if you have any questions after reading the manual that you should down load at 1-800-323-9651 or e mail me at jeffc@htproducts.com Let me know you were on the wall. Thanks Jeff Cook0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
