Bill @ Honeywell
sootmonkey
Member Posts: 158
Bill, Hello, I am full of dumb ideas. Here is one of them. Could an aquastat be made with all of the wireing termanals external of the control? For instance, the 8124 would come from the factory with all the conections pre wired to a female "pigtail". (like on utility trailer hook up). Then field wire the boiler components to a male pigtail. My reason for this is my fat fingers, limited space in control box for wireing and I think my idea would make life easier. Your thoughts?
Bill @ Honeywell
Bill, Hello, I am full of dumb ideas. Here is one of them. Could an aquastat be made with all of the wiring termanals external of the control? For instance, the 8124 would come from the factory with all the conections pre wired to a female "pigtail". (like on utility trailer hook up). Then field wire the boiler components to a male pigtail. My reason for this is my fat fingers, limited space in control box for wireing and I think my idea would make life easier. Your thoughts?0 -
Prewired controls
Thanks for the input! We are using the "universal" philosophy on many controls like our R7184U oil primary, S8610U gas ignition and R8845U universal relay. The whole idea is to simplify service and consolidate inventory. I will pass this info on to the guys in the market, whose job it is to develop/improve products. I welcome feedback from the field guys "in the basement", keep it coming! BTW, field tech's ideas aren't dumb. Give yourself credit, you work with these things daily, and know what makes your work life easier!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
