concrete slab??
David Sutton_2
Member Posts: 63
whats the normal depth of pex in a concrete slab ?? how far below the surface is it?? thanks guys
Depends!
We have done jobs where we stapled the PEX right onto the foam underneath a 4" slab. And we have also attached the PEX to re-barb and they have pulled that into the center of the 4" slab.
Jamie
Pompetti Heating & Air Conditioning, Inc.
www.PompettiHVAC.com0 -
wire mesh
going to attatch it to wire mesh, done radiant, but 1st time in a slab. its just a entry way, 227'of 1/2 staddler pex0 -
Is this just going to be a wet-bed or an actuall concrete pour?
Structural Concrete Slab
The top of the tube should be embedded in the slab to a minimum depth of 2 inches below the surface.
(RPA Standard Guidelines, para 16.1(a))
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com0 -
thank you Tom (nm)
,0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
