SNOWMELT DESIGN BUILD
John_21
Member Posts: 34
may have had an influnce on the numbers. John
RECENTLY A DESIGN BUILD SNOWMELT JOB CAME UP TO BID. THIS JOB WAS A CLASS II TYPE JOB IN SOUTH LAKE TAHOE CA, 6200' ELEVATION. APPROX 20,000.00 SQUARE FEET, 32,000 FT 3/4 TUBING. THE BTU LOAD BETWEEN THE FOUR BIDDERS RANGED FROM
ABOUT 200 BTUS PER SQUARE AT THAT ELEVATION TO 300 BTUS PER SQUARE FOOT AT 6200' WITH AN 80% EFF APPLIANCE.TUBE WAS ON 10" CENTERS. WHY THE WIDE RANGE?
Based on experience, the load per sq-ft depends upon various parameters, such as snow fall rate, % of surface you want to be totally free from snow/ice, response time etc. Also, it depends a lot upon the type of control system you have ( either fully automatic or manually operated ) .
Within the latest ASHRAE
snowmelt classifications are some choices. While there are still three classes, they also have various percentages of snowfall melt included. So it's possible that various class 2 calcs could present a spread in btu/ sq. ft loads depending on the % chosen.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
