RauPanel - DF
hot_rod
hot_rod Member Posts: 23,818
This was our first project using Rehau RauPanel. There was a bit of a learning curve but it went smoothly. According to Rehau literature, it has outputs very similar to poured underlayments. I will find ot next winter. -DF
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=262&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Michael_6
    Michael_6 Member Posts: 50
    raupanel
    Dan, we found in the homes we did last year that the output was even better than our poured underlayment projects and there was no comparison on response time.
  • kevin
    kevin Member Posts: 420
    dan...
    what is going on top for the finish floor?kpc
  • Dan Foley
    Dan Foley Member Posts: 1,265
    RauPanel
    Kevin,
    Hardwood strip flooring is being installed on top of the RauPanel. We started this system yesterday (60* ambient) to test it out. Within 30 minutes, we had to shut it down because the carpenters were complaining it was too hot. It heats up fast!
    -DF
