unico system
Irene
Member Posts: 22
I know that most information on this wall is about heat, but I am looking for someone to install a unico air conditioning system in my brownstone in Brooklyn Heights. I have called the company and tried all the people they have recommended. Almost impossible to get a return call, so I thought I'd try for some personal recommendations.
Irene
Irene
high velocity
I have done some brownstones with Unico in Brooklyn in the past with much success except for the parking.
Sorry to say I have retired from Brooklyn installations due to the amount of work on Long Island.
You may want to call Jerry Katz @ ATS ...516-538-3348. He may have a similiar product and some dealers in the area.
I hope that helps.
Good luck,
Brian0 -
Find a contractor
Irene, did you try the find a contractor feature on the upper left hand side of the page? If you type in you zip code you can find the nearest 10 contractors. They are professionals and if they can not do the job for you I would bet that they can recommend some one.Try it , it's free.!0
- 125 Chimneys & Flues
- 19 Recall Announcements
