Need a circ for 450 degrees!
450 degrees. oil based heat tranfer liquid. low gpm - 7 to 12. low head - 25' total loop, open system, highest pipe is 5'. runs up to 6 hours at this temp 1 to 3 times a week.
competition found one for between 3 and 4K plus installation.
any ideas?
manufacturers... e-mail me if you have one that works.
clients son is my new apprentice so guess who gets the job!
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Curious
    What are you building, Richard?
    Retired and loving it.
  • Richard Miller_2
    Richard Miller_2 Member Posts: 139
    A torture chamber.
    seriously, it is on an existing system. this fluid is circulated through a large drum roller and used to print fabric through a heat transfer process.
  • Kevinj
    Kevinj Member Posts: 67
    I piped in a hot oil unit for a customer a couple years back. I think the machine had a Taco pump. I do not have records as we only piped it. If you don't find one let me know and I can check with my customer.
  • Art Pittaway
    Art Pittaway Member Posts: 230
    Try Cornell Pump
    our of Portland Or., they made pumps for cooking oil circulation. They also make pumps that will pump fruit and vegi's without damage. I don't know if they make a small enough pump for your application. That temp will need a cooled seal or sealless (mag drive) for any decent life from the seal before replacement. $3K to 4K...maybe, check the spec's of what you offer and if the end user goes for cheap....let the buyer beware!
  • Roger Link
    Roger Link Member Posts: 15
    high temp pumps
    You might try to contact the rep for Dean Brothers Pumps in Indianapolis or SIHI Pumps in Grand Island NY. You might also check www.pumps-ez.com .
  • jerryb
    jerryb Member Posts: 113
    Try Goulds Pumps one of the biggest manf.
  • flange
    flange Member Posts: 153
    these are industrial pumps you are looking for. dean should be able to supply you. on systems such as this, it is not reccommended to use screw pipe, use either 3000 lb socket weld or buttweld fittings. it will save you aggravation later. a lot of the older military plants are hthw, used to have one in a local pro stadium. any unions should be socket weld, copper face ground joint. stuff is expensive but your customer already knows this, dont sell yourself short.
