1-1/4 pex tubing
Ed cousins
Member Posts: 1
Anyone know where I can buy 1-1/4 pex tubing on the east coast. Thanks Ed Cousins
Big pex
When I bought some here in Nebraska, I think they actually had to import it from Sweden. I had to get the brass compression by pipe thread couplers to use on the ends too. The book shows propex rings for 1 1/4, but I guess you need a big power tool to use.
The compression type worked real well, but now in retrospect, I should have done a minitube type of system to supply that manifold.
If you need it now, or if you are using this in a radiant heating application, maybe you should consider another option. Or maybe someone out east stocks it.
Kevin
pex
Check out your Rehau distributor they will be able to get some 1-1/4", and the fittings fairly quickly.0 -
Big pex
What I have done in the past is run 2-1" lines and tied themtogether at both ends. Tubing and fittings are readily available. Don't know if that helps. I would hate to have big pex and find I needed 1 more fitting just to wait for transcontinental shipment. Good luck. Let us know if you find large pex.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
