one inch pex
Wayco Wayne
Member Posts: 615
turning radius of 1 inch pex. Never worked with pex that big. I imagine it's like wrstling an anaconda. How tight can you go with out kinks??? WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
1\" bend radius
is 10". Nice, big turns!
John0 -
My supplier
(Rehau) tells me it is the o.d. x 5.
Large Pex bends
I don't know if this is helpful, but I have bent Pex up to 1 1/4" by shoving it through large diameter plastic conduit bends. I do this when burying supplies to manifold locations. I then duct tape the bend to a piece of rebar driven in the ground. If I remember correctly, the 1 1/4" Pex took about 2" diameter conduit bends. It's a bit of a wrestling match, but works great. Of course if you wanted a bend in the middle of a long run, an open bend support would be very handy, how 'bout it Wirsbo? Kevin
- 125 Chimneys & Flues
