baseboard radiators?
dale_5
Member Posts: 2
I am trying to find some baseboard radiators to replace a standing radiator in a residential home. This is for a friend of mine who lives in the north and I don,t know or see to much radiators down here in the south. Any advise on who or where to look would be greatly appreciated.
www.burnham.com
John@Reliable0 -
traditional or
other?
www.runtalnorthamerica.com has some great options.
Michael Bleier
Able Distributors.com
"The Supplier Who Works With You"0 -
Dale, does your friend have
a hot-water or steam system?
If this is a hot-water system, the baseboard must be sized using the same water temperature the rest of the system uses. Otherwise you will get too much or too little heat.
If it's a steam system, it must be piped carefully or it will bang, spit and not heat. See Dan's book "The Lost Art of Steam Heating" for details.
Also, the new baseboard should be the same material as the old radiator. Cast-iron behaves very differently than fin-tube and it's not a good idea to mix the two.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
