dhw
ken_6
Member Posts: 33
from a fuel dollars point
why a 90% tank type such as cyclone vs 90% boiler + indierct
or visa versa?
or visa versa?
dhw questions
The cost of the boiler and indirect is definitely higher, and you would most likely not go with a boiler if not wanting to heat the house too. If you already have a boiler, then go with the indirect. The 90% you mentioned does not include, residual heat loss, standby stack loss. Eff. is higher with the combined system. As far as your other question about gph rating terms etc., there are a lot of terms to describe how much water can be produced. some are to tell what you can produce in the first hour, some for what you produce in a constant flow, and a self contained unit already has the ghp @ a certain degree rise figured out, but with a boiler/indirect the gph of hot water is also directly related to the size of your boiler, and temp. settings on it.
How about life span.......
A great boiler and indirect will last for more than 20 years while a Cyclone, Polaris or Voyager.............well, considerably less.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
dwh
the scenario is were called in to upgrade apts
eff. so we are replacing heating boiler with high eff anyway
the question is from a gas bill perspective only
a leave existing tank type dhw
b replace with cyclone type
c indirect off of high eff boiler0
- 125 Chimneys & Flues
- 120 Geothermal
