Suspended Radiant Floor Heat (concrete)
Patrick Kozak_2
Member Posts: 23
Mike, I'm in the planning stage of building a home in which I'm putting a workshop below the attached garage. I've found a bridging product that has the foam insulation formed on it.As soon as I get home from work I'll e-mail the URL link to the company website.
Could someone direct me where to find information concerning the specific heat and "r" value of concrete, and concrete products, such as bridge decking.
There is a job where the owner wants to heat an area with radiant, but the underneath of the "overpour" is 8" bridgedecking, and is not insulated from the underneath. The final slab thickness will be 12". The space below is enclosed, and it will be tempered, but not heated to 70 degrees. The construction is new, and all first quality.
How do you figure how much heat it takes to raise 1lb of concrete 1 degree f? How about 1 sq. ft of concrete?
Mike0 -
Bridge deck heating
Mike
First some questions,
Is this to be a room above the deck or is is a snowmelt?
If it is a room then you need to talk the client into adding at least one inch of insulation first to the deck then complete the 3" additional overpour.
You could also add a 2-4" layer of insulation to the underside of the original 8" concrete deck (glueing it).
Then you would just use any standard heat loss program to calc the heat load.
If this a snowmelt then the same considerations enter the picture but are more important since your heat load is much higher.
Watts/Heatway heatloss program has the flexibility to account for all of these conditions.
We encountered a similar job of a actual bridge some years ago that the client wanted to snowmelt along with terraces around the building. We used the Heatway program to figure it out. On the same job we radiantly heated a sewer that was suspended from this bridge to keep it from freezing during our Chicago winters.
Hope this helps and have a Dynamic Day
George0 -
Polysteel PanelDeck Insulated Decking
Mike, The URL for this product is www.polysteel.com Hope this makes the job easier.0 -
Polysteel Website Down?
I can't get there from here.0 -
polysteel.com
Mike, I tried the website a few minutes ago and it came up saying page couldn't be found, but it had the option below to click on the same URL www.polysteel.com When I clicked on it I was sent to the polysteel site. keep trying, let me now if it works. Also I'll email you the page on PolySteel PanelDeck.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
