Optimal loop temp and sizing question
Brian V
Member Posts: 7
Hey all,
I'm getting ready to replace my single pipe steam system with a hydronic system and have a couple of questions.
Boiler design temp.....
This will be an oil fired 4 section, will also be using an indirect for my domestic.
What is the optimal loop temp? The manufacturers I've been looking at all give a range that they will operate at, but what is best for the boiler? When sizing baseboard, what temp do you use? I do plan on using a reset control, maybe not at first but definatly down the road sometime.
Thanks all,
Brian
Thanks all,
Brian
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
