Banging Steam Pipes
Sal
Member Posts: 1
I recently purchased an older home (built in 1935) that has steam heat.
Ever
> time the steam heat comes up the pipes on the top floor are banging. The
> noise or banging is so loud it wakes up the hole house in the middle of
the
> night. I tried to correct all the radiators so they are on the right
pitch,
> I bled the system, I tried everything but the banging is still there. What
> can I do? I'm afraid I will have to open the wall or floor to correct this
> problem because we can not live with this sound. Also, I had an engineer
> check the house before I bought it and he was not able to detect this
> problem, should he have found this banging pipe. Please help....
Ever
the
pitch,
If The...
...engineer held himself out to be competent to inspect a house with a steam heating system, then he should have been able to indentify any problems or shortcomings, and note them in his report.0 -
Try to find out
where the banging is coming from. Then go to the Find a Contractor page of this site to locate someone who can fix the problem. It's not hard to do if you know what you're looking for. If you're in the Baltimore area, e-mail me.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
