under slab insulation??
what type matirel do you recomend to put under concrete slad for radient heat????
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    A min. of.......
    2" blueboard or similar, high density foam board, is whats used around here. Believe its somewhere around 40-50#/sq.ft. stuff. Moisture is the killer with any insulation, and even this stuff is not water proof. Good drainage is a must, and a good vapor barrier under the insulation is needed. Moisture wicks heat away in a hurry.
    Steve
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Standard Guidelines
    The Radiant Panel Association puts out a booklet: "Standard Guidelines for the Design and Installation of Residential Radiant Panel Heating Systems".
    The list price for the booklet is $12.00. It is also available for review free online at:
    http://www.radiantpanelassociation.org/i4a/pages/index.cfm?pageid=115
    Senior Designer/Trainer
    Precision Hydronics Corporation
    www.precisionhydronics.com
  • kevin
    kevin Member Posts: 420
    ditto...
    to Steve. Some others may try bubblefoil but styro is real nice to work with. I use the wirsbo stapler and the job goes quick and the tube stays put. kpc
