Baxi wall hung boiler
b young
Member Posts: 28
Stopped by a wholeseller's place today and they handed me some lit. on a new boiler by Baxi. The Baxi Luna 310 Fi to be exact. This is a wall hung boiler that has a out put of 35,000 to 105,000 and can do domestic water as well. It can heat 180 gph at a 77 deg temp rise. It comes all piped and you simply connect to your manifolds, or that is how the lit goes. Has anyone ever installed one and if so what kinda of luck have you had with them? Just curious, they are priced right and look great!
They're
all over Europe. Great stuff.Retired and loving it.0 -
Check out this thread
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=37044&_#Message37044
Your question was posted on The Wall a couple of weeks ago...
I'm going to try one on a job this spring.... All the research I've done points to a good unit.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
