Pumping Forward
Jamie_6
Jamie_6 Member Posts: 710
On lower budget jobs do you guys still put the pump on the supply side of the system? Or do you pump forward of the expansion from the return side?
  • clammy
    clammy Member Posts: 3,242
    budget
    even on a budgt job mount your circ. on the supply it's just a couple of fittings maybe they can do without a spriovent to save money and p.s. if the custemer is telling you how much they want to spend let someone else do it.the sweetness of a cheapened price is worst then the bitterness of poor quality.if you have to do a job cheap and below your own stanards why do it it most likly will cameback and bite you in the butt.i pas more job up over the people being cheap than i do. and the ones i made no money on and did right i never here from ,the cheap ones i did that the cust.or boss said didn't matter spent more time b.s. around to get it right.don,t sell yourself or your custmer short
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    Steamhead Member Posts: 18,213
    We always Pump Away
    every time we replace a hot-water boiler, and on system additions and modifications too. Customers are always amazed at how well it works.
    Consulting
