Residential chilled water fancoil variable speed?
Carrier has many options open to you
peace be with you
david c. broome
peace be with you
david c. broome
Does anyone know of any chilled water fancoils, residential ?
Looking for chilled water fan coil. I could only find Magic-Air, I'm looking for E.C.M motor, variable speed if possible0 -
fan coils
First Company in Texas and one I cannot think of right away.0 -
Also check out
www.multiaqua.com
I believe www.unicosystem.com and www.hi-velocity.com may also be able to help. I seem to remember a company called "Fan Tech" or Fantech.
They're out there, you'll get something definite here in a little while.
Happy heating, Brian.0 -
ecologix.ca
Ecologix manufs a H/C air handler that is three stage heat and fully modulating cool and yes it will take a chilled water coil.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
