RAU-PANEL
Bob M.
Member Posts: 7
Just used the RAU-PANEL from REHAU to do a bathroom floor and the walls. The stuff was easy to install and heated up very fast when I started the system. I thought there would be a tin sound to it, but when the material is installed it is out solid as wood. I found it to be easier to install then Climate panel, no calking in the track, just walk it in.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
