Adding another mixing control to Tekmar 363
bruce pirger
Member Posts: 111
I am using a Tekmar 363 to control a variable speed injection pump to control the temp in my slab floor (using outdoor reset and indoor sensor).
I would like to add another variable speed injection controlled loop, i.e. another mixing pump control.
I can use a Tekmar 362. Seems kinda like an expensive way to do this....is there anything simplier? A 150 setpoint isn't quite right...
Thanks for the help.
- 120 Geothermal
- 394 Solar
