Tim D. our local WirsBuddy
Jamie_6
Member Posts: 710
Tim,
I am looking @ a job where we will be installing radiant panels on the second floor of a home. I would like to us Wirsbo tubing and manifolds to feed each panel. (that way we could get trickey & zone it later) What temps can the tubing handle?
Thanks,
Jamie
Thanks,
Jamie
tubing ratings
Jamie,
From the web site.
73.4* @ 160psi, 180* @ 100psi, 200* @ 80psi
Hope this help.
Ant
You may
want to consider Pel-al-Pex tubing for this application.
Wirsbo Multi-core or Kitec as PAP tubing has much lower expansion than Pex.
Hope this helps.
Mark H
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
