Current Project - DF
hot_rod
Member Posts: 23,405
We used a Buderus G124X sidewall vent boiler to supply two hydro-air units, one indirect (53 gal. Buderus) and the radiant zone. It was a tight squeeze in the mechanical closet. A Tjernlund mechanical fresh air intake supplies combustion air. The indirect and air handlers are in an adjacent mechanical room. -DF
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=262&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Remodel Job.
This is a project we wrapped up today - a kitchen/sunroom remodel. The existing terra cotta tile was demo'd and removed. We added a layer of poly insulation and Watts-Radiant tubing. That's Wayne Coleman and crew from Blue Ridge Radiant pouring the gyp. -DF
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Nice place
Wouldn't want the bill for those windows!
Retired and loving it.0 -
How about
a pic of the mechanicals? Nice project!!
how thick...
was the polystyrene board. How does that affect the stiffness of the floor? What did they use for a finish floor? Tile,hardwood,pergo? kpc
Insulation
Kevin,
We used 1/2" thick extruded polystyrene insulation. That was as thick as we could go without affecting the existing glass in the sunroom. The finish floor will be polished limestone.
-DF
Dan
where is the indirect located ? The horizontal unit would have been good for this , or do you not have the room behind the boiler ?
Scott
Indirect
Scott,
I have used the horizontal indirects in the past and they work well. In this case, we would have had to pre-pipe and slide the indirect and boiler into the closet - not easy. It would be almost impossible to access the piping for future service. It was easier to use the vertical model in an adjacent closet. -DF
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
