Honeywell Gas Valve
actual model is VK 8115V - 1077 used on Weil mcLain and Munchkin boilers. Honeywell has no information on this control and attempts to get information from Munchkin folks has been to no avail.
Does anyone have access to information on this valve and the procedures for adjusting and setting it up?
There is some info in Weil McLain book but it is different from Munchkin valve.
Honeywell advised me that
this valve is not available in US and must be dealt with through thier Netherlands division. My experince in the past with such things is not good. I hope that Weil McLain and Heat Transfer Products will make these availble to local supply houses. If you have to wait a couple of days for a gas valve it can get awfully cold. These valves also need adjustment at the time of installation and there are certain citeria for testing them. I am having a very hard time getting information about these controls.0 -
Local Supply
just got calls back from two suppliers, these valves are not available from my local suppliers they are OEM only valves.0
- 167 Indoor-Air Quality
