Nozzle Info needed for Wayne ER oil burner
Randy Berg_2
Member Posts: 44
I am trying to found what is the correct angle nozzle also solid or hollow for the Wanye ER burner that was made for Weils Mclain. This is a four section boiler M/N P443, which was installed around 1970. Thanks
I've found narrow and solid work best. Most people replace the gun.60*0 -
Randy.
Go back to OilTechTalk & your original post. I found my 1967 literature & answered your question w/ all the info you need. It is listed right under your request.
RON THANKS
RON THANKS
Ron, Thanks I got the info.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
